Coil building with .045 magnet wire
  • Coil building with .045 magnet wire
    Hey guys, I am building a coil for my TGSL. All I had handy was a few spools of magnet wire that is a bit larger than the .025 that is specified. I have met the inductance requirement on my Tx and Rx, but the resistance is (obviously) too low. Can I just add an in line resistor to get the resisitance in spec, or do I just get the correct wire size? Thanks for the help.
    give it a try, though i would put it on the coil plug, or on the coil plug connection in the enclosure.
      Try the TX on the TX oscillator if it oscillates it's ok. If not you need a different TX design to use it.
      You could try a resistor. The TGSL has been used with lots of different coils so it might work. I used
      0.55mm wire at 45 turns with the Minelab oscillator (see IGSL thread) and it works fine!
      Higher resistance is generally better for the receiver but lower should just give a bit more noise. So
      add a bunch of windings or not and see what happens...
        Thanks for the input. This is my first coil, so I am trying to be careful. I just picked up a large spool of 22 Guage wire that should serve me well. I have 5 coil housings from Bill Hayes to use up, so these windings are going to show me what shape will fit in the housings with room to move for nulling.
          I made a bunch of coils to Ivonics TGSL specs and finally got a good one. Then I bought the
          Belgian coil housing that I though he was using but the housing is 10 1/4" and the coils are 9 1/2"!
          Darn I guess I'll have to buy some more wire....
          Let us know how you got them to fit. The housing I have is a bit tight and I wonder how to make
          the coil to fit and be adjustable. My old coil was big where they crossed so I would have to have a
          deep housing to use it. I'll null it on a piece of plywood or something and experiment with it for a while
          anyways.
            U need a coil shell for Ivconic's pattern?
              That might be easier than winding new coils. I just checked and they measure 9".
              I just looked on your site (I hadn't seen it before I ordered) and it says shipping
              rates apply. What does that mean?
              SD
                Great site. Do you take Paypal?
