You're correct, it IS complicated. Things that make it like this include:
*The ground gives a signal, and the size of this differs with frequency, increasing with f. So a higher f will in principle not help you get depth.
*Different discrimination circuitry give different results - analogue vs DSP microcontroller, simple vs complex
*Search-coil size matters. Big coils don't find tiny targets so well, even though in general they seem deeper. The tiniest specks I've found have all been with the 5 inch DD coil, eg. shotgun lead shot 2mm diameter
*Probably coil shape, too, DD vs concentric, round vs elliptic.
*Then factor in target size, vs. metal type. You will find that targets with 'corner freqs' of 1 - 3 KHz are all quite large, eg U.K 2pences, US Quarters, so they are easy to find by virtue of being large, so a detector that runs at 10 -15K can still find them deep. But it will also find smaller targets, becausethe frequency match to the target improves.
+many other things.
+many other things.
