I am getting a little confused with coil inductance. I thought they had to be the same or very close, i understood that in a concentric design one coil is bigger than the other so the number of turns will be different to achieve the same/similar inductance.
I was looking at this http://www.hobby-hour.com/electronic...ack-gr1290.php towards the bottom of the page it suggests to build a larger coil and gives the diamentions. i used the coil calculator from this forum but it gave me confusing answers. the tx coil was about 6.18mH but the rx coil was about 67.3mH. I understand what the bucking coil does but wasn't sure how to fit it in to this calculation.
am i calculating it correctly? or are the measurements wrong? or is it all correct and the way this detector works takes this into account?
i am trying to get an more of an understanding on how the coils work i am just using this as an example.
thanks
thanks
