Which cable and connector to connect a PI coil?
    Here's the picture: Click image for larger version
Name:	RG58 and 150 cable side by side.jpg
    Left is RG58, right is the 150 Ohm cable. You can see a small spiral PE wire sticking out with keeps the center conductor in place.
      Originally posted by joop View Post
      Here's the picture: [ATTACH]30838[/ATTACH]
      yes I see the microphone cable looks smaller and has a stranded center conductor.I measured my microphone cable today and it comes out at about 50pf per meter, ok but not great.
      Thanks Joop!
      Dan
        The 150 ohm cable looks similar to those used in cars between the FM receiver and antenna.
          Almost... coaxial cables inside a car has a 93 Ohms impedance. The only reference I could find against 150 Ohm impedance is microphone cable or networking cable, but then it is always twisted pair.
            heelo joop
            use high flexible koax microphone cable und the 5pin connector with screw ring
            it is the best solution
            DONT use cable with massive core wire - danger of cable break
            high flexible cable is also more comfortable
            http://kleinanzeigen.ebay.de/anzeige...915?ref=search
              When using coax connectors, I usually use a "wrench on" instead of a "crimp on" that way I don't have to buy a crimper. Just saying.
              Good luck.
              Richard
                Hey Joop, This is what I use for my coil to control box for cable and don't seem to have any problems. Its soft and flexible as well so wont damage as easily. Just food for thought.
                http://www.rapcohorizon.com/p-552-soundflex.aspx
                  Thanks guys!
