7" Bounty Hunter Coil Conversion To Tesoro Specs
  • 7" Bounty Hunter Coil Conversion To Tesoro Specs
    I bought an old Bounty Hunter 505 ID (nonworking) at the Flea Market for $10 and
    decided to modify the 7" coil to work on my TGSL.
    I opened it up by slicing all around with an xacto then pried the housing away from
    the foam inside. It was a little tough but using a paint scraper helped get up inside.
    I picked out all the foam bit by bit;
    Revealing the RX and Buck coils;
    TX and notice only the bottom housing is painted with conductive paint;
    I attached drain wires then painted both half's with graphite;
    And glued the new TX (wound to 6.2mh) down;
    Next to wind the RX and Buck...
    Your quality of work is top notch, waiting to see it finished.
      you make your own graphite paint or you buy it if you made it how. i am gonna try i have graphite sticks and boat varnish i think there's a thread about it somewhere.
        I'm using this stuff in an easy to apply spray can!
        http://www.tractorsupply.com/en/stor...-12-oz-aerosol
          I saw your reply in another thread a few days ago. I've been wanting to try graphite shielding. When I saw it keeps grass from sticking to the mower deck I had a few reasons to purchase some(shielding,available locally, mower deck and cost). I bought a quart can at the local tractor supply not knowing if the spray can would be enough for the mower deck. Made a test coil. So far it looks good, passes the hand test. Would like to test for attenuation and if it's better to cover just the coil or cover the housing. I see in your post above they covered only the bottom of the housing. Thanks for the information.
            I've seen other coils where they put a square of copper approximately 2" x 2" and
            tied that to shield for grounding. So it's possible a full shield is not necessary...
            The spray stuff is easy to apply, though I got a clog after 2 coils. I think the graphite
            sometimes clumps. I was shying away from shielding until I found this stuff!
