Weight
  • Weight
    Ok friends,
    using epoxy resin there is no problem to fix and complete the coil but the weight increase too much.
    Can I mix epoxy resin with something else or use it only in some parts?
    In this last case, what can I use to fill the area?
    Was this argument already discussed inside the forum?
    Any suggestions are well accepted.
    Thank you, guys.
    Glass bubbles.
    Grt Nakky
      Another better?
        Polystyrene foam and a mix from epoxy and glass bubbles.
        Grt Nakky
          Grt Nakky
          Sorry but I am not sure at 100% about glass bubbles...
            Well your looking for microsphere's that are used for epoxy filler like this;
            http://www.aeromarineproducts.com/mi...FaHm7AodFFgAkw
              I do not know where do you found these informations...
                Sorry, I am an ignorant.
                  Grt Nakky
                    Glass "bubbles", look here : http://www.easycomposites.co.uk/prod...rospheres.aspx
                      Originally posted by greylourie View Post
                      I assure you that I never seen them before.
                      This forum is full of people that know many things.
                      It is a beatiful solution and I would like to try them therefore I am going to order some packs.
                      Thank you.
                        Or you can use a lightweight epoxy resin.
                        See RT380 -> http://www.resintech.co.uk/products/potting.htm
                          whites uses something like 'pena montazhnaja', do not know how write in english. POLYURETHANE FOAMS???
                          all tell it 'makroflex'. i think their site http://www.makroflex.com/en/products.html
                          odnako makroflex for coil has to be VERY SPECIFIC, because DOES NOT ENCREASE IN VOLUME. ORDINARE MF is ENCREASING AFTER freezing in 3-5 times!
                          you have to find out the NON-SELF-EXPANDING foam -!
                          The foam is self-expanding and during the curing process expands about 2 to 2.5 times.
                          do not ask me WHAT uses whites - I simply do not know!
                            Also this one is very interesting!
                              I know this product as "polyurethane foam".
                              Can be is good, I will try it as soon as possible.
