A Coil Calculator question
  • A Coil Calculator question
    When using insulated multi-strand cable is the diameter with or without the insulation? Thank you.
    The diameter should include the insulation.
      Same goes for enamelled copper wire. Results are more accurate if diameter over the enamel coating is used, although there isn't a lot of difference.
        Again thank you, it clarifies my question. Grateful.
          The calculator has worked twice for me but the others times I have tried it I can only put my info in the top three lines but nothing else works. What am I doing wrong ?
            That is all you do then calculate and the rest fills in automatically.
              Nothing happens when I click on the x at the bottom. Calculate button is not showing up.
                I can only assume that you have a different calculator or a corrupt program. go here and download the calc. http://www.geotech1.com/forums/showt...oil-Calculator
                  That's the one I am using, Downloaded it still same thing. Thanks I'll keep working on it.
                    Sorry but on my version there is NO X on the bottom. I just put in the 3 values in the top boxes and click calculate and the lower 3 boxes fill up with info. If you are still having trouble, I am sorry I cannot help you further, does it work on another computer?
                      Which operating system are you using, and which browser?
                        Windows 7 and internet explorer. I clicked on tools and enabled scripting.
                          I have tested the calculator software on Windows 7 with Internet Explorer, and it works fine. In fact, it should run on any platform that supports JavaScript. It's also been tested on Linux and Android, and with various browsers such as IE, Google Chrome, Firefox, etc., with no problems.
                          Have you tried a different browser, such as Google Chrome?
                            No I'll try that and see what happens. Thanks
                              Tried goggle chrome same thing. When I open the calculator up nothing is there between inductance line and copyright where the calculate button is on the picture of the calculator
                              Is there some settings I need to change on my laptop or what am I missing.
