Whites V3I coil specs
  • Whites V3I coil specs
    Because I'm an electronics tech with a curious mind I had to do a little investigating with my coils. This is what I've found.
    The Rx portion of the coils is on pins 1&2.
    The TX portion is pins 4&5.
    You can see the pin numbers if you use a magnifying glass.
    The resistance and inductance of the coils are as follows:
    Eclipse 5.3
    RX= 30.8 ohms 14mH 40 Rings
    TX=3.3 ohms 561uH 19 Rings
    Eclipse 4x6
    RX=50.9 ohms 15.6 mH 29 Rings
    TX=3.3 ohms 545uH 17 Rings
    Eclipse DD 6x10
    RX=55.2 Ohms 14.0 mH 31 Rings
    TX=3.4 ohms 550uH 19 Rings
    D2 Stock Coil
    Rx=44.1 Omhs 13.73 mH 32 Rings
    TX=3.3 Ohms 550uH 21 Rings
    The rings is a "Q" test of the coils and is an indicator of shorted turns.
    As you can see the TX and RX of all the coils is similar both for resistance and inductance.
    I was able to measure the inductance and "Q" with a Sencore LC103 test set I own.
    This info should help anyone if they believe they have any coil problems.
    I'm assuming all my coils are good and from these results I think I can safely make this assumption.
    I did read that MXT-DFX coils are compatible with and have to work on Vision. correct me.
      Not sure.
      I've never owned either the MXT or the DFX so I can't say.
        The MXT DFX coils will work but not in 22.5kH it has to be V rated coil ( it will work but not to full potential of the V detectors)
          How White V3i connects Garrett's 2500 Hawk Eye part
            v3i does not connect garrett.
              https://www.youtube.com/watch?v=pLSXdXRjsz8
                Did you change the link TX RX
