I Need Help To Build Mono Coil For Minipulse Plus (Rev-D)
  • I Need Help To Build Mono Coil For Minipulse Plus (Rev-D)
    Hi Friends I'm new here any one can help me to bulid a mono coil ? which wire and what gauge and how many round plz guide me for the best suite coil
    What kind of targets do you seek? What will be your primary targets? Artifacts, Jewelry, coins, small gold nuggets, battlefield relics?
    Where do you think you will be detecting? Beach, mountains, mine dumps, parks, old battlefields?
    Each of your choices will result in tradeoffs and will set the coil and detector requirements.
    If your answer is "all of the above" then you will need several coils and your detector will have to be capable of adjustment for 'very fast sampling'.
    Dan
      Dear Mr Dan,
      Thanks for ur reply my targets is Coins and Artifacts i want to make 22",18" Mono and 14" DD coil and I'm trying to Make Minipuls Plus (Rev-D) and Microcontroller P.I Treasure Hunter. kindly help me i would be very great full to you
        If you are hunting for coins and general artifacts, 22"/18" will be too big, you will miss smaller objects - bigger coils may give more coverage and depth but will not detect smaller targets
        It is generally considered that for coin hunting a 9" or 10" coil is best
        Use the coil calculator http://www.geotech1.com/forums/showt...oil-Calculator
        It will show you how many turns you require, make sure you enter radius not diameter
          Silverdog's advice is good and there are many on the forum who have experience in detecting artifacts. I have no experience in doing that and cannot provide detailed advice in that area. It does seem that if you seek large artifacts a larger coil would allow you to cover more ground quickly but the large coil forfeits sensitivity to smaller targets. Perhaps others can provide advice on appropriate coil sizes for artifacts.
          Dan
            Thanks for ur reply i all ready send u an inquiry through ur silver dog shop a few days before but u did not reply kindly check that my email is mrhethero@yahoo.com plz reply me here ...
              Unfortunately i do not ship to Pakistan
              How deep does it go ? There is no one answer for that, it depends on many factors
              For an average coin depth will be roughly the diameter of the coil
                thanks for reply,
                u can use the Post office services to send me to Pakistan if possible for u? and let me know if i buy all those components here in Pakistan and build a home made pcb u will help me ?
