if we use Litz wire to build 18" mono coil for Minipulse what would be the results any body explain ?
using Litz Wire to build 18" Coil
Don't try it unless you are well versed in coil construction and the technology involved. If not build an 8in coil to a plan first and get that going. An 18 in coil would be good for depth on LARGE objects but would be foul on small objects at any depth. Do search here and learn all you can.
Best Regards Eric.
Originally posted by MMTDETECTORS View Postif we use Litz wire to build 18" mono coil for Minipulse what would be the results any body explain ?
I hope this helps?
Joseph J. Rogowski
