What is the difference between the two types of coil Tesoro make
Delta Coils ((4-pin HOT(High Output Technology))
Epsilon Coils (5-pin µmax coils)
Name TX-L TX-R (ohms) TX-fo TX wire RX-L RX-R (ohms) RX-fo RX wire
Brown 8" 5.59mH 21.2 --- --- 6.23mH 22.1 --- ---
White 8" 5.68mH 21.8 --- --- 6.36mH 22.8 --- ---
White 4" 5.62mH 26.6 --- --- 6.13mH 28.2 --- ---
uMax 9x8 5.74mH 24.6 --- --- 6.21mH 25.8 --- ---
uMax 12x10 5.78mH 17.3 --- --- 6.15mH 18.9 --- ---
Specifications look very similar between the two
Trying to build a concentric 5.75" for a Bandido II µmax but can't find any specifications. The only information I have found is
5,75 "concentric
............................. Rx (2-4) 65,0 Ohm .......... 68.38 kHz
............................. Tx (1-3) 3,8 Ohm ............ 251 0 kHz .......... 5 mV
resistance looks to high?? on the Rx and very low on the Tx more like a Lobo
5,75 "concentric
