Garrett ACE and AT coils
  • Garrett ACE and AT coils
    I had chance to compare ACE and AT-series coils.
    measured from plug
    ACE 6.5" x 9": 2.5mH / 4.7ohm and 1.89mH / 31.5ohm
    ACE dd: 2.5mH / 4.9 ohm and 1.90mH / 28.6ohm
    AT dd: 2.5mH / 4.8ohm and 1.90mH / 24.4ohm
    Big question - what is difference? Both have trimmer inside. I don't have AT coil internal schema.
    It's likely that the residual null signal is lower for the AT coil than the Ace one. The AT coil's shielding might be better, too.
    I say this because the AT will obviously run at higher gain than the Ace, maybe double/triple, so coil nulling is more critical.
      Now I have broken AT DD coil. RX side had shortcut in coil side. Cable and plug were ok.
      I took pcb out and it looks same like ACE-series. Only 3 componets. Zero ohm resistor(jumper), 100 ohm trimmer resistor and 12nF capasitor.3 coils. 2.5mH 4.2ohm, 1.7mH 8.3ohm and one coil with very low inductance and resistance (tuning coil pallel with trimmer resistor . series with RX coil).
      Next thing is put all back without pcb and test it with ACE
        Fixed and working on test bench. Capacitor is left out.
          AT's PCB. Trimmer is placed under small sticker top side of coil.
            Today i made adaptor to connect my second AT coil to ACE250. It's working good on kitchen table. I see no difference.
            Is it same coil for both machines? Does anybody really know?
              Garrett Ace 150...........................6.5 kHz
              Garrett Ace 250...........................6.5 kHz
              Garrett Ace 350...........................8.25 kHz
              Garrett AT Pro............................15 kHz
              Garrett AT Gold..........................18 kHz
              wrong data on frequencies? can somebody give a respect light to right data?
                there must be some tolerance, kt's numbers above match the garrett specs, when you buy an ace coil the same one is for the ace range 150,250 and 350/euro, as said above the at versions may be better shielded.
                  Checked ace250 + ace dd coil. result 6.73kHz.
                    Tested 6 coils with ace250.
                    results
                    ACE DD 8.5" x 11" - 6.73kHz
                    ACE CC 6.5" x 9" - 6.71 kHz
                    ACE CC 6.5" x 9" - 6.73 kHz
                    ACE CC 9.5" x 12" - 6.78 kHz
                    ACE sniper 4.5" - 6.75 kHz
                    AT DD 8.5" x 11" coil connected to ACE - 6.75 kHz
                      Can someone tell which principle the the Ace 250 operates under please. I just purchased a used one and am new at this. I notice that it has no adjustment for ground effects and assume that this is most likely due to it's design principles.
                        Well here's a schematic that is supposed to be ACE. Click image for larger version
                        Maybe R48 is the ground balance?
                        Many detectors have a preset ground balance that should work most anywhere...
                          In a micro you may combine s portion of disc signal to achieve a better GB, provided the disc channel does not saturate. If you allow saturation, a perfect trigonometry becomes impossible.
                            Say what?
                            Barry
                              Seek a schematic of Fisher 1265 and see how it handles discrimination. It happens in a baseband (1-10Hz) and that's what ACE see on its ACD inputs.
