The cable for the search coil
  • The cable for the search coil
    Hi. Which cable is used for the coil and where to get it? Share links. Thank you.
    http://www.metdet.ru/Sensor_20_1.htm
    На рисунке ниже показан способ подключения датчика с помощью S-VHS кабеля Belsis BW7809PL.
      The proposed cable that you will not do for the metal detector (quickly breaks down) lasts for 2-3 months of operation. Проверено на практике.
        My detector cable (Minelab GPX) appears to be a standard Televison ariel cable. Easily purchased from electronics store.
