I would like to fix "The world's simplest coil calculator". Inductance isn't proportional to circumference of the coil but proportional to its area. If we try to transform the circle to ellipse then inductance will be decreased (area also) but circumference will be the same. Therefore we can modify the world's simplest coil calculator formula as follow:
L = k*S*N^2
S - the area of the coil;
N - number of turns;
k - inductance factor, that can be measured by the testing coil with a few number of turns;
This is also not perfect estimation certainly, but allows more exatly getting into the "right ballpark".
L = k*S*N^2
