coil hookups
  • coil hookups
    just wondering if you could use a bounty hunter gold nugget 4" coil on a whites prizim3 ofcourse i would need to no the right wire config if any one happens to no that would be awsom
    Well maybe, I have sucessfully used a BH coil on a Tesoro by cutting into it and removing the cap inside.
    Different coils use different inductance's and are sometimes tuned by having caps inside. Usually you
    cannot just rewire it and have it work on another detector.
    Here's a schematic to a white's coil;
      I found this today;
      Anyone know the wiring Bounty hunter coil to older White's coil connector?
      For an old White's coil in my notes I have, Pin 1 - black, pin 2 - red, pin 3 -shield ground, pin 4 - white, and pin 5 green. The pins are numbered on the plastic with 1 and 2 closest together at the bottom, pin 3 on the upper left, pin 4 on the upper right, and pin 5 in the middle. For the Bounty Hunter the pins are in order 1 - 5 and they start at the bump on the bottom and run counter clockwise 1 - 5. Pin 1 is red, 2 is black, 3 is grey, 4 is white and 5 is green. For the coils to be inter-changable, the frequencies need to be close to the same, and the two wires for the receive coil and for the send coil have to be matched to the correct pins on the coil. The older whites frequency was around 6K Hz, and I,m not sure about the Bounty Hunter. Hope this helps.
