Coil Housings
This one looks like coils from Gary (Chemelec). Data says 18pf so it's still good.
Coil housing I've seen from Bulgaria, around 15$, but I don't think they are sold internationally.
I have seen many housings being made in Ukraine (check olx.ua).
https://olxbg-ring02.akamaized.net/i...oborudvane.jpg
Originally posted by rickb View Post
You will have to fill the tabs but they are quite functional.
Don
look this seller http://www.md4u.ru/viewtopic.php?f=31&t=4901
thats real casting. he sends overseas.
Molded DD and Mono.
Prices:
Housing Cast DD 320 × 337mm 160 UAH / pcs. in stock.
Height 14mm housing.
The height of the lugs 35mm.
The distance between the ears 20mm.
Material Glass-fiber reinforced polyamide. Drilling amenable tugovato, very strong, not fragile, the material used for casting heavy duty parts (gear, etc.), Food processor.
Colour Black, matte, appearance looks rich.
Weight 206 grams.
Vlog Roman Koval, homemade DD320x337 sensor test the instrument Garret ACE 250 https://www.youtube.com/watch?v=2P7-nTLDYtg
Housing Cast Mono 240mm 90 UAH / pcs. in stock.
The height of the lugs 32mm.
Material ABS plastic.
Weight 168 grams.
Bolts M8 and M6 20 UAH / pcs. in stock
Sending across Ukraine new mail.
t.0959000393 Andrew
[email protected]
