Garrett ace 250 coil connector pin layout
  • Garrett ace 250 coil connector pin layout
    Hi all. Can anyone tell me what the coil connector pin layout is on a garrett ace 250 . Which pins are tx and rx. I need an induction balanced coil with preferably pin layout as attached diagram
    Ian
    What I Have.Click image for larger version
Name:	D - ACE_sch_1__1_.gif
      Thank you for that. I have made plenty of pulse induction coils but induction balanced is another kettle of fish. I would like to make one some time but for trailing the Fortune M an off the shelf coil would be better.
      Ian
        Lots of Time Yes, Hard NO. What detector do you need a coil for ?
          Its for a Fortune M. It has got good discrimination, fast recovery and very sensitive in gold mode.
ID:	347811Click image for larger version
ID:	347812Click image for larger version
ID:	347813Click image for larger version
Name:	ACE_250 coil_sch.gif
ID:	347814Click image for larger version
ID:	347816Click image for larger version
ID:	347817Click image for larger version
ID:	347818Click image for larger version
                So this detector uses a coil of 6.5Khz ? Maybe you can find another coil runing 6.5 or 6.6Khz that could work for you. Just need connection details ?
                {\rtf1\ansi\ansicpg1252\deff0\nouicompat\deflang10 33{\fonttbl{\f0\fnil\fcharset0 Calibri;}{\f1\fnil Calibri;}}
                {\*\generator Riched20 6.3.9600}\viewkind4\uc1
                \pard\sa200\sl276\slmult1\f0\fs22\lang9 ok. so i put a freq table again, from archive, and we will mind what to choice for the mister.\par
                \par
                Best frequency to use:\par
                US Dime = 2.7 KHz\par
                Gold Coins & other US Coins = below 10 KHz.\par
                Us Nickel & gold Jewelry = 16.5 KHz\par
                Gold Nuggets = above 20 KHz\par
                ---------------------------------Metal Detectors based on Operating Frequency\par
                Blisstool LTC64X v3...........Base operating frequency: v3 - 8.0 KHz\par
                Adjustable operating frequency (+/-60Hz)\par
                Bounty Hunter Land Star............6.6kHz\par
                Bounty Hunter Lone Star............6.6 kHz\par
                Bounty Hunter Pioneer 505........6.8 kHz\par
                Bounty Hunter Quick Silver.........7.0 kHz\par
                Bounty Hunter Texas Pilot...........7.0 kHz\par
                Bounty Hunter Time Ranger.......6.9 kHz\par
                Bounty Hunter Tracker IV............6.6 kHz\par
                DeepTech Vista Gold................25 kHz\par
                DeepTech Vista Smart.............15.5 kHz\par
                DeepTech Vista Rebel ..............8 kHz\par
                Discovery Treasure Baron.......12.5 kHz\par
                Fisher 1266-X.............................4.8 kHz\par
                Fisher 1270x...............................8.2 kHz\par
                Fisher 1280-X 8" Coil................2.4 kHz\par
                Fisher CZ-21 10" Coil.............5,15 kHz\par
                Fisher F2.....................................5.9kHz\par
                Fisher F4.....................................5.9kHz\par
                Fisher F5.....................................7.8kHz\par
                Fisher F70.................................13 kHz\par
                Fisher F75.................................13 kHz\par
                Fisher Gemini-3........................82 kHz\par
                Fisher Gold Bug I......................19.2 kHz\par
                Fisher GoldBug II 6.5" Coi........71 kHz\par
                Fisher GoldBug II 10" Coil........71 kHz\par
                Fisher Quicksilvers (CZ-5, CZ-6a and CZ-20) operate on two frequencies \f1\emdash 5 kHz and 15 kHz\par
                Golden Sabre Plus .................. 15 kHz\par
                JW Fishers 8x ............................100 pps\par
                Garrett Ace 150...........................6.5 kHz\par
                Garrett Ace 250...........................6.5 kHz\par
                Garrett Ace 350...........................8.25 kHz\par
                Garrett AT Pro............................15 kHz\par
                Garrett AT Gold..........................18 kHz\par
                Garrett Deepseeker.................... 5.5 kHz\par
                Garrett Gold Scorpion.................15 kHz\par
                Garrett Groundhog.....................15 kHz\par
                Garrett GTA..................................6.5 kHz\par
                Garrett GTAx_500.......................7.0 kHz\par
                Garrett GTI 1500..........................7.2 kHz\par
                Garrett GTI 2500..........................7.2 kHz\par
                Garrett GTP 1350........................7.2 kHz\par
                Garrett Infinium Land & Sea.......730 pps\par
                Garrett's Sea Hunter ............ 750 pps\par
                Garrett Treasure Ace 300...........6.4 kHz\par
                Minelab E-Trac............................1.5-100 kHz\par
                Minelab Excalibur II - 8" Coil.......1.5-25.5 kHz\par
                Minelab Excalibur II - 10" Coil.....1.5-25.5 kHz\par
                Minelab Eureka Gold...................3 frequency (6.4kHz, 20kHz, and 60kHz)\par
                Minelab Explorer SE Pro............28 different frequencies, from 1.5kHz to 100kHz\par
                Minelab Musketeer Advantage Pro...5kHz\par
                Minelab Quattro MP.....................28 different frequencies at once, from 1.5kHz to 100kHz\par
                Minelab Sovereign.......................BBS - 17 different frequencies at once, l.5 kHz to 22.5 kHz\par
                *Minelab Sovereign and Excalibur operate over a broad range of frequencies (2 - low of l.5 kHz to 22.5 kHz \emdash 17 individual frequencies simultaneously.\par
                Minelab X-Terra 70....................(VFLEX compatible) Coil Frequency Options......3 (Standard 7.5 kHz, Low 3kHz, High 18.75 kHz)\par
                Minelab X-Terra 305....................2 (Standard 7.5kHz, High 18.75kHz)=(coil frequency options)\par
                Minelab X-Terra 505...................3 (Standard 7.5kHz, Low 3kHz, High 18.75kHz)=(coil frequency options)\par
                Minelab X-Terra 705....................3 (Standard 7.5kHz, Low 3kHz, High 18.75kHz)=(coil frequency options)\par
                Shadow X2 was listed as low a 9.6 kHz\par
                White's Beach Hunter 300..........(Multiple Frequency)\par
                White's Coinmaster Pro..............8 kHz\par
                White's Coinmaster GT...............8.192 kHz\par
                White's E-Series DFX 300.........3 kHz, 15 kHz, or use both frequencies\par
                White's Goldmaster GMT..........50 kHz\par
                White's Gold Master Vsat.........50 kHz\par
                White's M6 Matrix Series..........14 kHz\par
                White's MXT 300........................14 kHz\par
                White's 6000X
                QXT.................................6.59khz
                IDX,
                ID,
                CL III,
                5900.
                White's MXT Pro........................14 kHz\par
                White's Prizm II.........................8.2khz
                White's Prizm 5G.........................8 khz\par
                White's Prizm 6T..........................8 kHz\par
                White's Sierra Madre..................6.5 kHz\par
                White's Treasure Master...............8.2khz
                White's SL series........................6.59 kHz\par
                White's Spectra V3i....................2.5, 7.5, 22.5 kHz\par
                White's Spectra VX3..................2.5, 7.5, 22.5 kHz\par
                White's Surf PI.....................600 pps\par
                White's Surf PI Dual Field..........800 pps ?\par
                White's TDI 6.595 kHz
                White's XLT..................................6.5 kHz\par
                Teknetics Alpha..........................7.8 kHz\par
                Teknetics Delta 4000..................7.8 kHz\par
                Teknetics Gamma......................7.8 kHz\par
                Teknetics Omega.......................7.8 kHz\par
                Teknetics T2..............................13 kHz with frequency shift option\par
                Texas Titan 9000........................6.6 kHz\par
                Texas Titan 9000 Pro.................6.6 kHz\par
                Texas Titan 9000 Pro Plus.........6.6 kHz\par
                Tesoro Cibola............................14.3 kHz, 14.5 kHz, 14.7 kH\par
                Tesoro Compadre.....................12 kHz\par
                Tesoro Cortes............................10 kHz\par
                Tesoro DeLeon..........................10 kHz\par
                Tesoro Golden uMax.................10 kHz\par
                Tesoro Lobo...............................17.5 kHz\par
                Tesoro Sand Shark.................600 pps\par
                Tesoro Silver Sabre \f0\'b5Max........10.6 kHz\par
                Tesoro Tejon..............................17.2 to 17.6 kHz\par
                Tesoro Tiger Shark...................12.5 kHz\par
                Tesoro Vaquero........................14.3 kHz, 14.5 kHz, 14.7 kHz\par
                XP Deus....................................4,8,12,18 kHz \par
                  Thank you. Plenty to choose from. And yes would need to know connection details once have decided which one to use.
                    Tell me please, the exact marking of the antenna connector in the ACE block, I can not find it.
                      Hi homefire
                      What mean " /par" in you frequency listing? Thanks.
                        Normal !
