is it possible to make a home made coil my kid she is only 10 and the coil it too heavy for her, i was thinking of a shell and filling it with foam beads to make it light as possible ?
garret ace 150
Best kids ACE coil solution. Deep almost as 5x8 stock coil:
http://www.detecnicks.co.uk/Garrett_...iper_Coil.html
it was set right for her height and i not paying as much for a coil as i did for the detector, why sell a detector with a solid resin filled coil, the thing is the coil is the part that weighs most on the detector, i even find it heavy to use, has anyone got a diagram or that how to build one ill give it a go
No idea what they are like but remember this post
http://www.geotech1.com/forums/showt...=bounty+hunter
Originally posted by kosacid View Postthe only thing i dont get where dose R1 tap in to the coil after 83 turns then another 83 ? thanks WM6 and is the coil side by side or on top of each other ? seems on top of the TX
ye and @Koala thats what i should have got her lol
Bucking coil should be placed on top of TX coil (mean same dimension, coaxial)
L3 is wound in the same direction for the receiver
L2 is wound the other direction and on top of the receiver.
It can be done but not easy to build a concentric without some knowledge and an oscilloscope.
For example a few millimetres out in diameter will affect the number of turns of L2.
Cant see this going to well for a first build.
Took me a few attempts to get a good coil with a good shield. Without the add pressure of making it super light.
By the time you have bought the shell, wire, connecting cable, connector, resin and strain relief it will not be much cheaper.
Do find it annoying that the sniper coil is 20-30 dollars cheaper in the USA
secondhand maybe ?
