Square Coil 40 x 40 cm for SNIFFER
  • Square Coil 40 x 40 cm for SNIFFER
    I made a square coil 40cm x 40cm with FTP CAT 5 (3 turns of 8 ) for a SNIFFER and I have R=5 ohm
    Could it work either it is too much?
    Thank you for your help
    Better try 4 turns of 4 ,or 5 turn of 4, dont separate the pairs.
      Ok ....... But what are the best values coil for Sniffer or (Delta Pulse), diameter, inductance, ohm resistance?
        Thank you Xtrem for your reply.
        But 4 turns of 4, that is maybe the same like 2 turns of 8 (FTP CAT 5)?
          Coil has to be about 500μH, >=2Ω.
          4 turns 4 ,are the same turns like 2x 8, but 4x4 has less resistance and less self capacity between the turns ...better coil.
            Good understood! Thanks
              Hi aurum
              try this nice and easy calculator for rectangle coils.
              regard
              www.eeweb.com/toolbox/rectangle-loop-inductance
                Thank you cvele for your help.
                aurum
