Damm Damping resistor
    There are basically 4 places you can choose to fit the damping resistor:
    1) On the PCB.
    2) In the coil shell.
    3) In the coil connector.
    4) In the detector enclosure on the inside of the coil socket.
    #1 results in the same damping resistor being used for all coils.
    #2 is a problem if you want to use the coil on different detectors.
    #3 is often tricky because of lack of space.
    #4 means that you could use (for example) a 5-pin connector, with 2 pins used for the coil, and 3 pins connected to different value damping resistors. Then the closest required value can easily be selected by a wire jumper in the coil connector. However, there may still be problems swapping between detectors.
    Other possibilities (already suggested) are:
    1) Add a selector switch to change resistor values.
    2) Use an adapter cable.
    Personally, I put the damping resistor inside the enclosure on the back of the coil connector.
    Yes I would like to have something inside the enclosure on the back of the connector and that was my original question Althought I do like the selector switch thing , What socket do you use for your connector ? and what do I do with R1 Do I place a jumper on it ?
      Originally posted by AirTester View Post
      Happy Canada day.
      Is that base mount on your detector 3D printed?
      It is all 3dprinted the face plate Case and mount.
        LOL, NO JUMPER in R1. That could be a DIRECT SHORT. Just leave it open.
          Hahaha that's what I was thinking but I thought id ask just to be Short lol I mean Sure haha , Thanks Homefire.
