Re: the foil. I found 3 different samples of 'regular' grade thin foil. They measure up as 0.0103mm ; 0.0109mm; 0.0138mm. I don't have anything to hand that would be sold as 'thick', 'strong', 'turkey roasting' etc, though I will have a look tomorrow. I've also managed to bag some thick foil sheet from a friend who works in the catering industry. It's from a 'silver' serving platter as used at wedding buffets etc. And it's a substantial 0.165mm thick. So I've got a pretty decent spread of thicknesses now. It will be interesting to see how good a straight-line they give for TC vs. thickness. The info on the web suggests it's not all 1000-series alloy (ie. near-pure alloy), so resistivity could be noticeably different.
Re: your previous decay/TC charts: Is there some labelling missing from the 'top right' one?
This tempco effect isn't helpful, I do my tests in a moderate indoor environment, and I've not considered cold or hot tests.
I was thinking about the non-linear decay's you're seeing. It seems logical to me that whether a thin sheet is 'thin enough' will depend on the linear size of the sheet. So for example a 25mm square sample may give a straight-line decay with a thickness up to 1mm, whereas a 10mm square may only be linear up to 0.4mm thickness. Beyond some certain thickness/size ratio, you'll start to see 'bulk' effects, and non-linearity.
