I had a new idea that shows promise and that is using the wrap-around shield (with gap) as a TX on a RX coil. D=140mm, Lcoil(RX) = 325uH. Wrap-around shield 0.5uH and R = 0.4 ohms. TX pulse 30us, rise time approx 2uS then flat top at 10A. Back emf at switch off 12V. Only the RX coil appears to need damping. Pulse Rep rate is at present 3000pps and current drawn 500mA at 5V TX supply. This rep rate could be reduced to around 1000 so as to be more economical on current, but I am stuck with the 3K at present in order to get the 30uS pulse width.
TX switch is IRFP220N with on resistance of 0.075 ohms and VDss of 200V. It is on a heat sink but barely gets warm. Shield gets slightly warm. I coupled the RX winding to a NE5534 stage just to see what is happening and it looks interesting. Both switch on and switch off decays of a target are plainly seen and sampling could take place after 1uS. A faster front end will be tried next to get more detail.
Modelling the arrangement on Spice would no doubt give more insight if anyone has the time.
Eric.
Eric.
