help coil DD
  • help coil DD
    Hello, I would like to know about the coil, if you put the tape first, around the coil and then the aluminum foil? or the opposite ?
    No need for new thread!
    Coil turns always need insulation, tape, etc, before shielding.
    Also, shielding WILL add capacitance which will change the coil's resonance frequency (Important if used on a VLF detector) and will slow down the coil decay on a PI detector.
    LOTS and LOTS of info in this forum so just read and follow posted links.
      do not mention aluminum foil!
      NOBODY did say you to use foil!
      IDIOTIZM GROWS UP AND GROWS!
