Coil testing completed
  • Coil testing completed
    I have concluded my testing of various coils, I thought I might post my results for anyone who might be interested. I tested with three different detector, The PI-1 in the Meatal Detector Handbook, Surf PI-1, and the Hammerhead board. The diameters of the coil forms were as follows, 20 CM, 25 CM, and 30 CM. I used #30 PTFE, 100/46 Litz wire, 400/46 Litz wire, 22 gauge enameled, and finally 28 gauge speaker wire. I found the coils to work about the same depth for a given diameter. I tired solenoid winding and basket weave. The coil detection results ran from the radius to almost the diameter of any given form. I did this test in are using the same metallic materials. I found the best of all the test subjects was the basket weave, 25 CM with 400/46 litz wire. My hope as this information might help members of the board in the future. Best to all Jim
    Do you have some inductance measurements please Jim?
      Tim the inductance was between 310 uh and 375 uh for all the coils. The resistance was between 1 and 2.2 ohms. I am sorry I did not write down each coils spec's, I got lazy an figured that if was in the ball park I would tested the coil. By the way you wouldn't happen to know the size of Litz wire the Minelab company used to make their coils ? Best to all Jim
        I would expect depth as you describe for same target.
        How did they do on Small, High conductive targets- a 0.5 Gram Australian gold nugget?
        This is where the basket weave and/or Litz should show a difference if they are build with lower C and have a proper value Damping R.
        Like to see your results.
          Waltr, I thought the basket weave with the Litz wire would produce a higher "Q" coil. The basket weave did have a much lower 'C" . I did tune the damping resistor to fit each coil. I tested with very small gold fillings I retrieved from a friend who is a dentist. My test were run with various U.S. coins an other metal objects. I think My best find is a Japanese (Sin ) coin. The size is about the same diameter as a US quarter, base material is copper. Best to all Jim
            400/46 sounds right. I remember reading it somewhere ages ago-probably here.(Try advanced search "litz" in coils).
            Enamelled basket weave is my choice, as litz of any kind seems darn hard to find and is costly.
            I have a 10x5 ML commanderDD & Coiltek 11DD that I use for my comparisons.
              Basket weave is to reduce inter-wind C.
              Litz to to reduce Eddy currents in the Coil.
              A Gold filling may NOT be Pure Gold (24K). The conductivity of Gold DROPS a lot when alloyed.
              Example of a Gold 14K ring (58.3% Au, 33% Cu, 5.5% Ag) is more like a US Nickel with a conductivity of about 2.6MS/m. Whereas 24K (>99.99%) is 24MS/m and a Krugerrand (22K-91.67%) is 10MS/m (lower than brass).
              Gold nuggets can be fairly pure (the ones found in Australia are 95-98% so have higher conductivity and very fast Decays.
                Thanks Waltr for the nice reply, I got curious about another Litz wire coil. I ordered 660/46 wire, basket weave form , and 20 CM in diameter. We will see how it performs. Thanks again Best to all Jim
