I know there's a relationship as when you use a small coil you find more smaller artefacts such as .22 cartridge cases and buck shot with a 5.5" coil than with a 10" coil
Doesn't seem to be much difference when air testing
Is there a formula for the optimum size of coil. Say X times the target diameter for example.
Or is it more the small coil sees less of the ground. So there is less chance of something like a piece of coke masking the weak signal from a small target
