PI Coil Calculator program
  • PI Coil Calculator program
    Hi Guys,,,,,I found this while searching the Net,,,,,,,I won't know how accurate is till I've tried it out later but I thought it may be of use to other forum members. Regards, Marty
    Nice many thanks looks perfect!
      Your welcome,,,,Marty
        The calculator in your link is based on the one at the top of the Coils Forum. It gives exactly the same results, but is coded in C#, and compiled as an executable for Windows. The only differences are that the original is coded in JavaScript, and designed to run on any OS in any browser, and the C# version displays the coil diameter in the results instead of the radius. It also shows the coil inductance in both mH and uH.
        If you click on the "About" button, the author gives full credit to the original version.
          Nice one Qiaozhi!!!!,,,,I didn't know that,,,,I just thought I'd download it when I saw it to see what it was like and if it was any use to anyone,,,,I've always used your Coil Calc on the forum for all of the coils I've made because they've always come out accurately,,,,thanks for the info. Regards, Marty
            This one I found to be very good, especially in the hundreds of uH range. I use this one for winding bundle coils for my pulse projects.
            I also use Coil32, it has multi loop add on for calculating bundle type air coil
              Thanks Dbanner,,,,added it to my software collection. Regards, Marty.
                I tried the one from the sticky on front page and didnt work, i kept getting a message to input terms, so i tried the one from marty and works fine, weird, here is how i was putting in the text boxes
                  [ATTACH]53074[/ATTACH]
                  Are you referring to the Geotech Coil Calculator -> Coil Calculator
                  What was the problem? It seems to be working ok to me.
                    The image that you attached does not look like the Geotech coil calculator.
                    Cheers
                      Cheers
                      everybody who got from me DVDs with archive SEES first folder named COIL CALCULATOR SOFT.
                      in this folder i collected all soft i meet in net. all were checked BY ME and WORKING.
                        ust redownloaded it right now, works fine, maybe a download glitch of some sort,
                        J
                          Try to use a comma (,) for decimal numbers instead point (.)
                          Let us know if it works
                            already deleted it from my pc, redownloaded and now works fine
