Just testing the TGSL board and wound the first 'D' coil following the info from TGSL 101 revision 07-29-2012 by Don Bowers.
Using the former and wire dimensions (0.25mm) as specified, (coil constrained with dental floss but not screened or epoxied)
the first half coil came out at 23.9 Ohms 5.94 mH
The frequency at the coil is 13.94 kHz when running in the Tx position
I wound a second coil with more turns than should be needed (115T)
Resistance 25.9 Ohms, Inductance 7.4mH but frequency 12.99 kHz when running in the Tx position
I'm puzzled why the frequency is lower ?
What should I be aiming for? 6.0mH & 6.5mH OR running frequency
P.S the -5V rail is nearer 6.5V
THANKS!
THANKS!
