Coil encapsulation
    Originally posted by Koala View Post
    Good question.
    I know from experience if it just the wrong side of null it preforms badly. But don't know why.
    Really? This is another phenomena I want to examine more. I used to null DD on 20? (plus minus a LOT does not really matter) and CC on 200? without obvious reason - its possible to null it where ever you want. Even when I played with oposit null, it worked well. I do not remember exactly, but for DD on 200? side, its little bit more sensitive to ferrous and on 20? side its little bit more sensitive to nonferous. But more than result of measurement, it was only feelings. Difference was hardly noticeable. Deep null was somehow unstable, bad ranges of GEB and Disc. Never understand why, even when I read all Tesoro threads several times, my brain is too weak for such amount of different and often contradictory informations
    For example... several times is mentioned, that correct GEB range is caused by phase shift. Well, try it. On both sides including deep null I set potentiometer almost into one spot to reject ferrite. Guess that it is more affected by Tx to Rx inductance ratio and Rx parallel capacitor.
    Please, get it with reserve, I spend 15 hours at work in row and these are only my faded memories.
    I have never found satisfactory answer. And yes, I have ITMD
    EDIT: question marks are degrees, it still does not show proper characters...
      20 phase-shift is not a magic figure that works for any detector. This is specific to Tesoro detectors (e.g. TGSL). This offset is required for the ground balance knob to be somewhere around the middle position, and for discrimination to work correctly. You can confirm this yourself by measuring the phase-shift on a commercial Tesoro coil.
      If you try to "deep null" the coil, it just won't function correctly, and will be unstable in use. Alternatively, if you null the coil with a phase-shift much greater than 20
      , the ground balance setting may be outside the available range of adjustment.
      On some coils you have to use
      200 (which is 180 + 20) because the RX signal is inverted with respect the TX.
      P.S.
      Use [latex]^{\circ}[/latex] to create the degree symbol.
      You can also use:
      [latex]\textdegree[/latex].
        I built some Bandido coil and if I went for best null on the scope it only had a 50/50 chance of working well
        After wasting much time I gave up with best null. Instead I use the scope to get to the null point the get some various targets and adjust for best results. These always work.
        my shield is made from cardboard discs covered in graphite by adding to one side the null alters but comes back to normal when the second is add.
        Bandido doesn't go down to zero discrimination. Small nails are always notched out. The phase doesn't have to be far out to move this up towards large nails and pull tabs. On my concentric 5.5" coil there is a s all phase shift either side the null point. Whether this is the reason I doubt it.
          Testing @ 27?C
          Yep, it looks fine in preview but not after it's posted. Sorry, it gets fixed when vBulletin fixes it.
            Deep null is not preferred because weaker targets have further to climb before breaking threshold, lower the threshold and detector becomes unstable.
            It is a trade-off.
            Either side of deepest null is better for max sensitivity without unstable. It is the amplitude of the null that becomes the baseline for the target signal.
            Just my guess.
              The lead/lag phase shift inherent in the search coil(20/180) for tesoro, is a function of the phase shifting circuitry, more specifically the ground balance . So designer make coil with phase shift circuit in mind. And also the tx resonant frequency Rx resonant frequency spread.
              I am sure engineers who design such devices have firm grasp of the science involved.
              Not easy to wrap head around.
              White's classic series use different parameters to arrive at same destination. However, there are strengths and weaknesses inherent in the subtle differences.
              So tesoro devices perform better than White's in certain conditions and vice versa, all having to do with the coil and shifting topologies. Do you want better discrimination separation or better ground balance capabilities? See.
              At least for the older devices. Haven't got a clue about the new ones
