Tesoro 5 pin Connectors
  • Tesoro 5 pin Connectors
    Any one know the maker or a source for the Female end of these connectors ?
    Homefire
    Switchcraft Slim Line series, try SL105
      Hi Homefire,
      The female end for these that would be mounted on your detector box are SL175FX, I bought a few of these for my TGSLs and they fit the coil that I purchased.
      The cheapest place I found them was here https://www.arrow.com/en/products/sl175fx/switchcraft as they had free shipping for me.
        Good Stuff. Thank you both. Order placed.
          Is there a standard wiring config. for these 5 pin connectors? (TSGL DD coil)
            https://dfiles.ru/files/s6obi13mk
            open folder COILS.
              Thanks but I don't really want to join the Fundancer movement, I just need the pin-outs!
                The dotted line indicates that pins 3 and 5 are connected together in the search head. This is because the TX and RX loops share a common connection that needs to be connected to electrical ground.
Name:	Tesoro Coil Connections.jpg
                  what is fundancer movement?
                    Thanks Qiaozhi....
                    KT.... that's what popped up when I opened your download link
                      if you meant some banner so i must say you nobody still gave me a site where i could be loaded
                      100...200...300MB of files. NOBODY. at least i am NOT in english environment and i DO NOT KNOW your part of the global internet.
                      also, to the word, this forum does not have possibility to keep big files value because copyright.
                      so you must just hope on the help outside. i wait from you THANK but i got just full disappointment
                      because you are clear speaking english guy.
                        Just a update. I did in fact receive the connector and Yep, it's da one. Super Happy Camper. Thank You Everyone. When you wire these up don't forget to put the Ground ( Shield ) related pins on the Negative legs of the coil.
                          you can stop all that if you use an Adblocer on your browser
                            I use Adblock Plus, and it stops virtually all unwanted nonsense.
                            There are some sites that complain if you're using an adblocker, as they claim they rely on the advertising revenue. You can then either turn it off for that particular site, or just not go there.
                              AdBlock plus is Firefox add-on? I noticed some strange things happening to my browser for instance new page opens up for unsolicited advertisement when I click on something. Maybe I need to update.
