Started to think about a 9" Lobo DD coil
  • Started to think about a 9" Lobo DD coil
    started to think about a 9" Lobo DD coil
    i found these Coil winding templates
    https://sites.google.com/site/dbcoil...ding-templates
    and printed it out, my printer did not print it in the correct size so i increase the size of the image
    until it was right for me.
    then i traced around the template and figured out that it had a radius of 188 mm
    the length of the line that you teased around the templet is calculated like this
    the length of the teased line 590mm
    590 divide d on pi(3.14) is 187.89mm that is the radius
    now i divide 187.89 on 2 to get the diameter 93.9 or 94mm
    i have Remington Industries PN155 24 AWG Magnet Enameled Copper Wire
    and if i remember correct it have the thickness of 0.549mm
    now i'm ready to use the coil calculator on this page.
    To figure out how many numbers of turns i nede for the TX and RX Coil
    Lobo wants :
    Lobo coil 9" 1.35 mH TX coil
    Lobo coil 9" 10 mH RX coil
    i upload 2 pictures of my coil calculations
    now i have to make the coil winding Jig.
Name:	RX-Lobo coil 9-tom  10 mH RX coil.png
ID:	371172Click image for larger version
Name:	TX-Lobo coil 9-tom  1.35 mH TX coil.png
    if you pros see that im not thinking right pleas let me now so i can correct it
    On second thought; Tejon and Lobo Super Traq even may share the same coils, since inductance is pretty close.
    Nel advertisement could be alright.
    But this do no good to you, because you have "older" series Lobo pcb. The "early" Lobo.
    So you have to search for coil with specs:
    Tx = 1.35mH - 12 ohms
    Rx = 9-10mH - 55 ohms
    Im winding the RX coil and use AWG24
    i have 155 turns , and im measuring it and get 8.6 ohm and 9.09mH
Name:	Bilde_1 2019-08-12_15-23-10.jpg
    Im getting close to the mH but Ohm is way off , whats wrong is it the AWG ????
      strange way to take templates from internet. at first you have to buy the enclosure for coil from geotech camraden (plus fitting, plus cable).
      then, sure under this size to do templates. you set the horse after the cart.
        you are right , thats what i tough to , but since i started this way i have to make EPOXY coil and make the shape my self .
        But what about the resistance ?? is it important to hit both the induction and resistance ??
        or is it ok whit just hitting the correct induction
          first mistake. you will get heavy coil. yes, there are garrett coils filled epoxy but its are small size.
          while i do not know your physical condition and may be you are strong men with strong hands.
          then certainly epoxy filling is ok.
