Coil for TANGRA pulse force
  • Coil for TANGRA pulse force
    Hi
    I would like to know something about a pi: TANGRA pulse force. A friend would like to sell it to me but the 130 x 130 cm coil is heavy and difficult to handle.
    I do not know the specifications of this detector (resistance of coils, inductance etc...) because their site is silent on this subject.
    Before buying it I would like to be sure that I could make a small coil of +- 20 cm in diameter or more. I have measured the large coil but the connector with the device is composed of 5 outputs and not of 2 only:
    5 1
    4 2
    3
    The measurements are as follows:
    1-2= 0.6 ohm 1-3= 0 1-4= 2.2 1-5= 2.2
    2-3= 0 2-4= 2.1 2-5= 2.1 3-4= 0 3
    I would like to make a coil with 2 outputs (for example between 1-4 or 1-5) of 2.2 ohm
    minimum. Is it feasible or do I have to connect all 5 outputs?
    Thank you in advance for your help.
    hi buddy
    yet one DP clone? can you put some pics of inside in a board view? can you give Part List of all IC's you see?
      Happy to hear you. How are you?
      It is impossible to send you the list or photos because I have not yet bought the detector, just waiting for the possibility to make smaller coils
