This implies that the in-circuit resonance is different to open coil resonance because of the Rx network and MOSFET.
The implication is profound. The Rd is a function of in-circuit resonance, which(the in-circuit resonance) can only be measured with an oscilloscope WHILE THE CIRCUIT IS OPERATING.
ALL OTHER SRF MEASUREMENTS METHODS ARE IRRELEVANT.(for PI)
godigit1, I think your intuition is correct!
This means that the value of C in the formula
is indeterminable, except by means of solving for C after the in-circuit resonance has been measured. in other words, If we use just the coil C, then the calculated value of Rd will be way off what is actually required.
