I hope the LCR and frequency measuring part is true about these.
Measuring coil inductance
I built this with modifications in value of POT, calibrating inductor and input voltage. http://www.zen22142.zen.co.uk/Circui...ance_meter.htm
The author used 1.5V input but i will use 3V. The author used 500R POT but i used 1K (mesures 980 Ohms). The author used 100uH calibrating inductor but i used a 1mH 10% calibrating inductor.
Anyone please examine if the values match and will work the circuit.
I will use oscope to measure frequency
I will test as soon as components values are approved by experts.
Thank you
I have put this to work and the this thing performs well with oscope as its tag team partner. I will compare the results with a branded high end inductance meter if i ever find one but based on measurements i removed turns to fine tune inductance of my DP test coil and the depth is much much better.
