Surfmaster's coil waveform problem
  • Surfmaster's coil waveform problem
    Greetings!
    I need help with my self-made 1 layer pcb surfmaster. The waveform according to my cheap oscilloscope (Which i can't screenshot it here) . it would look like the pink line on the attached image no matter what dump resistor is it. (Thank for Tepco's waveform images). And one more thing no sound at all.
    If you completely remove the damping resistor do you get the same waveform?
      Actually my dump resistor is 1K trimmer connected in parallel with the coil as variable resistor. No matter I rotate it CW or CCW, the waveform is the same.
        Remove the damping R... what do you get?
        Remove the coil... what do you get?
          your trimmer is low voltage and lowest power type. you must use high voltage type and with power >=2W, wire type, not resistive layer covered type.
          look pics https://www.google.com/search?q=%D0%...h=865&biw=1280
            OK Sir, I removed Dump resistor and here is the waveform (RED LINE)
            And the same waveform after removing the coil but pure square wave for TX Period and no small notch for RX Period like the red line.
              What to do if i can't get such a trimmer
                use a diggest of resistors - 820, 750, 680, 620, 560, 470, Ohm. on a bread board.
                https://www.google.com/search?q=brea...w=1018&bih=865
                or George's/ITMD damping tuning schematic.
                  Guys, I Know I may be seems to be new here but I have been here for awhile surfing the threads to do it right. I really need help because i need it up and running soon. And i will build it from scratch again.
                    [ATTACH]53250[/ATTACH]
                    Can you show some pictures of the pcb ?
                      It looks to me like your coil is not actually getting connected to the circuit. Maybe you have a break in the cable wiring.
                        check diodes on op amp input. i see one is shorted.
                          Ok sir here is the images
                            It isn't broken because when i test it with continuity mode using the multi-meter it beeps
                              None is shorted.
                              And when i hold the coil with my hand. The op amp pin 6 goes from 0v (Calibrated with offset pot) to 0.58v. no respond from the coil but that. and still no sound even with that!!!.
