Hi, I am planning to build a mono coil for a surf PI that has a diameter of around 10 inches. Are there any key factors that influence the depth? I am aiming for a coil inductance of around 400uH. Should I try and maximise or minimise the coil resistance? i.e. should I use thin or thick enamelled wire? What about the winding capacitance? Is this a big deal?
Best coil design for surf PI
Originally posted by bishop_slayer View PostHi, I am planning to build a mono coil for a surf PI that has a diameter of around 10 inches. Are there any key factors that influence the depth? I am aiming for a coil inductance of around 400uH. Should I try and maximise or minimise the coil resistance? i.e. should I use thin or thick enamelled wire? What about the winding capacitance? Is this a big deal?
https://www.geotech1.com/pages/metde...s/FastCoil.pdf
Originally posted by surfdetector View PostIf you have not already done so, you should give this article by BBsailor a thorough read. It contains virtually everything you need to know concerning making a simple mono-coil.
yes, new matter for you. unknown for you. sometimes DUAL FIELD BASKET coil.
https://www.geotech1.com/forums/show...l-for-baracuda
This is the link that you need if you want to get directly to the Basket Coil:
http://www.metdet.ru/Sensor_K1.htm
Pleasure
Originally posted by bklein View PostAnyone sell pcb’s for this (in US)?
https://www.ebay.com/c/1878035697
You might be better off just getting a PCB from Silverdog.
A 3DSS Coil does not require shielding,,It 'Self-shields' due to its geometry,,,I use them on all my P.I's and I have never had any issues,,until something better comes along I won't use anything else. They're easy to build, a little time consuming, and require more wire than a bundle wrap etc, but a lot less capacitance that makes for a faster coil that you don't have to shield. Check out the 'Chance P.I Build' thread if you have never built one,,great reference for the 3DSS. Regards, Marty.
Originally posted by MartyJ1963 View PostA 3DSS Coil does not require shielding,,It 'Self-shields' due to its geometry,,,I use them on all my P.I's and I have never had any issues,,until something better comes along I won't use anything else. They're easy to build, a little time consuming, and require more wire than a bundle wrap etc, but a lot less capacitance that makes for a faster coil that you don't have to shield. Check out the 'Chance P.I Build' thread if you have never built one,,great reference for the 3DSS. Regards, Marty.
Hi Marty which PI have you been using ?
The first P.I I ever made was the 'Surf' and I use a 257UH 3DSS with that. I use 300UH 3DSS with my 'Mirage'. I use a 350UH 3DSS with my 'Minipulse Rev D and E'. I use a 350UH 3DSS with the 'Barracuda'. I use a 350UH with my 'Pickini 4' (Which found me a diamond encrusted 18ct gold ring at over 12") and a 350UH 3DSS with my 'Felezjoo' (Which I'm still experimenting with). I made a 3DSS for my 'Gold-Max P.I' (Elliot) but haven't worked out yet why I'm having shielding issues with that no matter what coil I try. I hope that helps somewhat? I bind them with thin medical gauze bandage and just fibreglass them afterwards though I'm still in the process of building my updated Vacuum former so I can form proper shells for them. Regards, Marty.
