More noob questions...
    Not a computer person. Windows 10, Microsoft edge?
    Downloaded the coil calculator from Geotech onto a Windows 10 laptop and opened coilcalc.htm in Microsoft Edge ... works perfectly. No problems.
      Lamoiz, When you start the program do you get a message saying allow blocked content ?
        no nothing at all, I can just put values, and I don t have the calculate button ...Click image for larger version
Name:	Capture coilcalc.JPG
          I don't think it's a scripting problem ( eg. the browser security feature has blocked active content like ActiveX and scripts ) , because the coil calculator still visually appears normal with js disabled, it just doesn't calculate.
          If you choose the coilcalc.htm program by right-clicking on it, you have the choice of 'Open', but also 'Open with'. This second option allows you to choose other programs, such as Explorer, to run it. This may give you a workaround.
            Originally posted by lamoiz View Post
            no nothing at all, I can just put values, and I don t have the calculate button ...[ATTACH]53708[/ATTACH]
            In the coil calculator directory, is there a directory (folder) called "Antenna"?
            Inside that have a look for buttons/default. The calculate button is in there. I suspect your coil calculator installation is incomplete, as there is no blue background in your image.
              hi George, i opened all the files, and now i have the button, there is nothing written in it, but it seems to work. it works ! thanks for the advice.
                Sorry.
                This is all I get.
                User inputs can be entered but there is no calculation
                  Originally posted by MartinB View Post
                  Sorry.
                  This is all I get.
                  Cracked it. Read post #21, opened all of the files and now it works. Thanks for your help
