Hi All,
I've built the front end of the GS4 on a vero board for testing, although i have it working the depth is not very good. Now I understand it could be down to the fact I need to build the rest of the circuit.
But I am leaning to the fact I may have built a coil that is not the stated 436uH. The gate pulse on-time to the mosfet is 196uS. Anyone know the correct on time pulse duration?
Also, when the mosfet turns on the coil voltage only reaches -8 volts peak, at which time the mosfet turns off, I was expecting it to be closer to supply. Is the 8 volts correct?
On the circuit diagram there are two 1k Ohm 1 watt resistors, is that correct, couldn't I just use one 500 Ohm 2 watt resistor.
Finally, does anyone have the correct number of turns and wire gauge for an 11 inch diameter coil for this machine? The coil I built was using the inductor calculator.
Many thanks
Many thanks
