Originally posted by waltr
Can you add a little info on how you went about doing the coils?
Like Resistance measurements at the start and finish of the paint. I was getting 1480 on average when checked either side of the break in paint. This dropped the more I moved the probe toward the staring point. Not sure if that was too high.
Also the wire around the coil pressed up against the paint. I tried that method but didnt notice any change in resistance drop as the guy on the video said he did it for. Did it anyway.
Other than that the coils were good for range 13.5" but boy where they noisy. How did you manage to calm them down. Mine sounded like an SOS signal regardless of how much I nulled.
Also agree graphite is better than the aluminum foil for range and doesn't need the disc pot turning to cancel it out.
Any info you can recall when making your coils would be so welcome.
