I want to make detector search mono and dd coil for whites tdi sl. Can you help with inductance and omaj?
Whites tdı sl coil
For a mono coil L should be around 300uH and R should be less than 3 ohms or so.
For DD, the TX coil should be the same as the mono specs above. The RX coil has more flexibility; you can make it the same as the TX, or you can increase L to, say, 600-1000 uH and see if you can get it to settle. It will take some experimentation. If you can, the extra windings should improve sensitivity. R is not as critical on the RX coil.
