Whites tdı sl coil
  • Whites tdı sl coil
    I want to make detector search mono and dd coil for whites tdi sl. Can you help with inductance and omaj?
    For a mono coil L should be around 300uH and R should be less than 3 ohms or so.
    For DD, the TX coil should be the same as the mono specs above. The RX coil has more flexibility; you can make it the same as the TX, or you can increase L to, say, 600-1000 uH and see if you can get it to settle. It will take some experimentation. If you can, the extra windings should improve sensitivity. R is not as critical on the RX coil.
      Thank you very mucy.I will try
        Mr.Carl-Nc can you dual field coil information about
          The patent explains it:
          https://patents.google.com/patent/US7994789B1/en
            Thank you very much. Mr. Carl
                Can you help me how will the tdi coil connection be?
                  Seems you bought TDI SL board from Orbit.
                    Can you help me connector diagram.
                      In the coil connector, pins 2-3-4 connect to the "+" side of the coil, pin 1-5 connect to the "-" side + shield.
                        Thank you very much. Mr. Carl-Nc .l am try
                              I couldn't solve tdi sl connector.
