Been thinking making another coil to better detect #9 lead shot. The one I'm using. (Rx)two round 133mm coils side by side connected figure8 opposing, (Tx)oval coil over Rx. Wound with AWG28 magnet wire. 133mm is inside measurement of each spiral wrapped coil. Thinking of trying 100mm figure8 using AWG30 magnet wire. Single winding for each Rx, two stacked windings for oval Tx. Thoughts or anything else I might consider.
Optimizing PI Coils
Originally posted by Carl-NC View PostWhat do you mean "two stacked windings for TX"?
AWG28 has a time constant of .31us, AWG30 .19us. Hoping I can sample a little sooner.
Another option. Twist two wires together and wind a single layer spiral coil. Would make a wider coil. Any thoughts which might be better?
Originally posted by green View PostWind a single layer spiral coil, then wind another on top of it. Connect in parallel, 2 AWG30 in parallel same as one AWG27. Less resistance than my one layer AWG28. Winding the two layers at the same time would be better but I don't think I can without making something.
Try reshaping your round coils to oblong coils with a parallel straight section and a semicircle on each end. As you make the shape wider the area of the coil will be reduced and the inductance will be reduced. Try to find the optimum shape for detecting your desired target. As Carl said the #9 lead shot may best be detected near the coil edge. With an oblong coil about .5 to 1 inch wide parallel section you will be closer to the coil edge and also cover more ground in a single sweep. To optimize this coil shape you would need to make some different prototype shapes and test them with your #9 lead shot. Just optimize the coil inductance with a few more turns as the coil gets thinner to keep the inductance the same. Optimize the damping resistance value for each shape you try.
I recall Eric Foster making a long oblong coil to detect broken needles in spools of fabric. These broken needles had a very low time constant and passed very close to the long coil spanning the fabric width. You may be able to optimize this concept to detect your #9 lead shot.
I hope this gives you something to ponder and possibly try.
Joseph J. Rogowski
Joseph J. Rogowski
Picture of Rx connected opposing, Tx round or oval over Rx. Could try with AWG28 to compare with the 2 round coil figure8.
Originally posted by green View PostAnother option. Twist two wires together and wind a single layer spiral coil. Would make a wider coil. Any thoughts which might be better?
Don't know how to calculate required number of turns for odd shape coils, not round for same inductance. Thinking of winding some coils, 150mm inside diameter with 15 turns. Wind the mirror image and connect figure8(Rx). Wind oval Tx over Rx. Chart signal amplitude vs target distance at location a, b, c, d, e and f corrected for 15 ampere turns to see which coil looks better. I'm guessing the round Rx coils. If anyone knows it would save me some time.Attached Files
Green,
The web site 66pacific.com has many coil size calculators. Round coils have the most area for a given circumference but if you squeeze the round coil into an oval the inductance will fall relative to the less area of the oval coil with the same coil perimeter length. The area of an oval squeezed to 1/2 the coil diameter will have its area drop to 75 percent of the round coil. If you squeeze the coil to 1/4 of the coil diameter, the area will drop to 62.5 percent of the circle area. Use an inductance meter on the round coil and when you move the coil into an oval, watch the inductance drop.
What depth are you seeking for your #9 lead shot?
Joseph J. Rogowski
Joseph J. Rogowski
I'm looking for the best coil shape and diameter to get 1 to 2 inch detection for #9 lead shot. Maybe if I get smarter that might change. First is defining shape, diameter, turns and wire size. Maybe others.
Read your reply #19 again. Looks like you are suggesting an oval mono coil. I get better S/N with a figure8 Rx, reason I've posted figure8 shapes. Maybe I'm missing a figure8 shape I should be looking at.
Ordered some AWG30 magnet wire to see if better than AWG28. Some charts with AWG28. Targets chart straight line decay linear log after 3.5us. What might cause the decay signal to be lower between 2.5 and 3.5 us? Wondering if I should wind the AWG30 coils same number of turns.Attached Files
Originally posted by Carl-NC View PostWhen you take data do you subtract a no-target response from the target response?
Added a picture of part of the recordings.Attached Files
I thought you were, so if you're certain the data sets are correct then I don't know what might cause that. Usually you see an initial higher slope that dies out in about 1-tau, that's caused by the settling of the eddy currents to the perimeter of the target.
Originally posted by Carl-NC View PostI thought you were, so if you're certain the data sets are correct then I don't know what might cause that. Usually you see an initial higher slope that dies out in about 1-tau, that's caused by the settling of the eddy currents to the perimeter of the target.
Coil decay chart shows .17us tau, should be .217us
Looks like Rd isn't the cause. Maybe something with my coil.Attached Files
