'brutal' coil adjustment
  • 'brutal' coil adjustment
    My plan is to use the special Garrett GTI's 1500 45cm Detech coil for the Makro Racer.
    This coil measurement stuff is so totally not my area of expertise so I wonder if some here has any info.
    Also if its possible to create some shortcut which harms the circuit with these low-energy IB-end-stages.
    Usually they should be the same stable as if you shortcut some TV antenna and nothing bad happens.
    I've made already some Makro Racer coil tests 2 years ago and you can attach resistors or capacitors
    and almost nothing changes. Cause I wanted to make the 28cm less sensitive which didn't work. hahaha
    The tips also can be a little bit "hardcore" because I can deal with the possible risk.
    And the coils impedance etc. must not be adjusted at 100% but already 70% is good enough.
