I found some instructions of making BFO-metal detector from web. Now I'm wondering one thing. Everything else is quite clear to me (my experience of electronic is quite low, but I can handle the basics). How much the coil impedance is depended of wire gauge? For example if the instructions says that I should use 0,4 mm wire for coil (which I can only get 700 meters rolls). But I have 0,5 mm and 0,25 mm wire instead. Can I make the coil with same number of turns using those wires.
Reima Rönkkö
Kemi, Finland
Reima Rönkkö
Kemi, Finland
