Hi Mr Woody au
Your coil configuration will give great sensitivity but poor depth because the depth is controlled by the Rx separation which needs to be at least 2 x Rx coil diameter.
See US patent 6,853,194 by Nelson et al.
The other problem is that turns spacing profoundly affects proximity losses (Q). The winding method you are using does not produce the lowest inter -winding capacitance or the highest Q or the highest coil resonant frequency.
Also the inductive relationship between Tx and Rx (the ratio of their diameters) is critical in obtaining optimal performance. Also to get the optimal depth capability the coil needs to be in resonant tank circuit where the Tx is seen as a purely resistive load, the inductive and capacitive reactance’s canceling out. Then you can get coil magnetic moments of 9-10 fold higher than with our Pis’ we have at present. You also need to take into account the relationship between skin depth and transmit frequency which profoundly effects depth and also the frequency dependent component of magnetic susceptibility in high ferromagnetic terrains.
ElectroNovice
ElectroNovice
