bugwhiskers,
Can you share with us, the self resonant frequency of both the single-side coil and the dual-side coil connection?
Typically, when you double the number of turns, you make the inductance 4 times larger. Your single-sided 250uH coil should work for making a pretty good gold seeking coil at low delays. Shielding is the only challenge.
The best way to even attempt a double sided coil is to put the traces on the second side directly in line with the space between the tracks on the first side to minimize capacitance. When the tracks on both sides align, you have one giant capacitor.
The real problem with making a PCB coil is attempting to shield it. Any gain in making a high self resonant PCB coil may be offset by the capacitance added by the shield. That is why a simple bundle wound coil, made with Teflon insulated wire (AWG 30, 10.5" ID, 19 to 21 turns, short coax about 3 ft.) and two layers of polyethylene (PE) spiral wrap spacer, makes a pretty good coil that can fit a variety of coil housings and be easily shielded.
bbsailor
bbsailor
