Coil Inductane - Q Measurement
  • Coil Inductane - Q Measurement
    I saw content about coil values (inductance, Q etc.) but I couldn't see any information about how to measure them correctly.
    I have wound a coil and want to measure its values. I have a Hantek LCR meter.
    Which frequency range should I choose and measure? In LCR meter;
    There are options such as 100hz - 1khz - 4khz - 10khz - 40khz. The values change at each frequency.​
    I think that you should measure the parameters of the inductor coil at the frequency at which it will work in the detector
      but the frequency I want is not available in the lcr meter
        So you have to choose a frequency that is closer to the operating frequency of the coil.
          This is how I measure right now. I wonder if there is a different measurement method?
          I'm researching the values of other coils, have you seen such a topic?
            coil generator : tester of coils - Geotech Forums (geotech1.com)
              Something similar to this?
              http://www.cqham.ru/Qmeter.htm
                Here is some background reading on inductors ... and Q factor.
                Quote:"{b]I have a Hantek LCR meter. There are options such as 100hz - 1khz - 4khz - 10khz - 40khz. The values change at each frequency.​[/b]"
                The Q value changes because the inductive inpedance changes ... but the DC resistance does not change.
                As your coil will probably have a low resistance, like under 5 Ohms, your meter may not give accurate or consistent readings. An alternative method for measuring low resistances is:
                Pass a known current through the test resistor, and use a voltmeter to measure the voltage drop on the resistor. You can then choose a higher current, for example 200 mA, as your test current. This will then give you larger voltages to measure, which will make them more accurate.
                  Here's the wiki page that's missing from the above post:
                  https://en.wikipedia.org/wiki/Inductor
