hello
IDX pro concentric coil with copper foil shield
Originally posted by ifrenide View PostSo no problem if I use copper foil instead of graphite spray? the only l problem only when I dont leave a gap, otherwise it is ok to use cooper foil which doesn't expose a problem? am I right?
- Likes 2
Thank you all for your help, I will cut the foil into 4 segments and I will connect each one to ground directly, and see what wil happen, at least I know now that copper foil itself is not a problem, but it must just arranged in a specific configuration to act as a shield. one more thing , I think copper foil conductivity is an advantage compared to graphite spray, and companies prefer graphite spray because it is easy to apply in a big mass production, compared to copper foil which is more difficult to be applied
