Delta Pulse Sniffer X71 Coil Size
  • Delta Pulse Sniffer X71 Coil Size
    Can anyone tell me the best coil size to make for a delta pulse sniffer and what is the coil resistance that will work well?
    50cm
    1m
    For a slightly larger size, accurate information is required
    Thank You..
    You only need to post your question in one place, not in multiple threads.
    I have removed your duplicate post in the PI Technology Forum.
      make three coils 450, 500 and 550 uH coils and tell us about result. there needed experiment.
        I have 0.5mm wire. How many turns should I wrap it in a 60cm circle?
        How much should be the induction here?
          sorry for that
            begin to read this forum from start to finish. all in it.
            Delta Pulse - Geotech Forums (geotech1.com)
              Thank You
