Help With Replacement Cable For White's DFX Eclipse 950 Coil
    why i must believe you? are you ready to present the proofs to your words?
      Originally posted by August View Post
      Why are you reacting so hotly?
      I have worked with these cables since 1994, so I have my own opinion.​
      You are absolutely right. The monitor cable will not work. Verified!!!
        Click image for larger version  Name:	CIMG7443.jpg Views:	0 Size:	600.7 KB ID:	413727
        Judging by the photo you submitted, I see you are a skilled marketer.
        Why didn't you clean the coax and show it in the photo?
        Probably because:
        External diameters of cables from monitors - 8mm, 7.5mm, 6mm.
        On the coaxial conductors in these cables:
        In cables with an outer diameter of 6 mm and 7.5 mm, the central core of the coax consists of 7 wires with a diameter of 0.086
        mm (AWG39), these are monitor cables manufactured in the 21st century.
        In cables with an outer diameter of 8 mm, the central core of the coax consists of 7 wires with a diameter of 0.114 mm (AWG37)
        - these are mostly monitor cables of the last century.
        One question - for what period of time will the resource of 7 cores of such a cable be enough?​
          Probably because:
          for monitor it works, for PI it does not work... you are big specialist... clean the coax first. i still not see pics from your side.
            This thread is about Whites DFX (VLF circuit principle) and your argument is about PI detectors!
            I am ending this discussion, I will not waste my time on you.​
              give me the diameters of the DFX cable, then begin to disput LOL!
              и никогда не лезь в спор если нихрена ничего не понимаешь. ЭТО НЕ ТВОЕ. да, я может быть был сбит ответом Джорджа... бывает... тем более кабель SVGA подходит.
              читай Щедрина и Колоколова. если хочешь поспорить заходи в этот форум. я тебе на русском напишу LOL! Форум про радио и не только (ixbb.ru)
                Thanks for the responses. I certainly didn't mean for anyone to get into an argument! I tried cutting into one of the modern "slim" SVGA cables, but the conductors were very, very thin, and I didn't think it would hold up very well. I believe I know where I can get an older, thicker VGA cable, so I may try that next week. I also cut into a USB cable, and experimented with that, but it only has one shared shield and it isn't proper coaxial cable.
