Blue Max 256 loop works whites 6000 di pro plus????
  • Blue Max 256 loop works whites 6000 di pro plus????
    :confused: :confused: :confused: Please I help!!! Who of you knows if the Blue Max 256 loops works with whites 6000di pro plus????
    Thanks for your help!!!!
    Porfirio
    In a Word Yes
    The 256 was made for the older Whites that took the the 6b loops Like the 6000di,5900,4900 Eagle 1 and with update chip.I think the Pro Plus was the first that came out with the 950 blue max.But the 256 will also work but very heavy,Alot of guys like the 256 on the XLT.You might check your meter and see if it reads right and will ground balance ok.
    I use all the Whites loops and bounty hunter loops on my Eagle 2.The older 6b loops and the Bounter Hunter loops are not as deep but lighter.I ask Whites if using the older loops would harm the circuit and they said, no.
    Paul WVa
      Paul WVa
      Thank you very much Paul, of your very precious information!!! As regards from Rome, Italy!!!
      Porfirio
